Introducción
The Terracopter EVO controller motherboard is used to control all of the functions of the controller and relay them to the drone.
Qué necesitas
Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
Remove the battery cover from the controller.
Paso 3 Protocol TerraCopter EVO Controller Opening
Aviso: los pasos 3-4 provienen de una guía que está marcada como "En progreso".
Orientate the controller to where the battery compartment is facing upwards.
Remove the four 5mm and four 4mm Phillips #1 screws from the case.
Locate the single pin holding the negative and positive wires to the motherboard. Each lead should have one pin holding each wire to the green side of the motherboard.
Using a soldering iron, melt the existing solder point for the red lead (positive line).
Using a soldering iron, melt the existing solder point for the black lead (negative line).
Pull the red and black leads through their respective holes, out of the motherboard.
Una persona más ha completado esta guía.
