Saltar al contenido principal
Protocol Slipstream EVO Propeller blades Replacement
Qué necesitas
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: paso 1, imagen 1 de 1
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: paso 2, imagen 1 de 2 Protocol Slipstream EVO Propeller blades Replacement: paso 2, imagen 2 de 2
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: paso 3, imagen 1 de 3 Protocol Slipstream EVO Propeller blades Replacement: paso 3, imagen 2 de 3 Protocol Slipstream EVO Propeller blades Replacement: paso 3, imagen 3 de 3
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
Conclusión
Michael Dang
Miembro Desde 04/10/17
301 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S3-G3, Liner Spring 2017 Miembro de UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 536
