Saltar al contenido principal
Protocol Slipstream EVO Propeller Guards Replacement
Qué necesitas
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: paso 1, imagen 1 de 1
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: paso 2, imagen 1 de 2 Protocol Slipstream EVO Propeller Guards Replacement: paso 2, imagen 2 de 2
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: paso 3, imagen 1 de 2 Protocol Slipstream EVO Propeller Guards Replacement: paso 3, imagen 2 de 2
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
Conclusión
Michael Dang
Miembro Desde 04/10/17
301 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S3-G3, Liner Spring 2017 Miembro de UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 171
