Saltar al contenido principal
Protocol Neo-Drone AP Motor Replacement
Qué necesitas
  1. Protocol Neo-Drone AP Motor Replacement, Motor: paso 1, imagen 1 de 2 Protocol Neo-Drone AP Motor Replacement, Motor: paso 1, imagen 2 de 2
    • Remove the four blades by pulling them off of the motors.
  2. Protocol Neo-Drone AP Motor Replacement: paso 2, imagen 1 de 1
    • Remove the blade guards by pushing the guards downward towards the padded feet.
  3. Protocol Neo-Drone AP Motor Replacement: paso 3, imagen 1 de 1
    • Remove the four 4.5mm Phillips #0 screws from the back panel.
  4. Protocol Neo-Drone AP Motor Replacement: paso 4, imagen 1 de 2 Protocol Neo-Drone AP Motor Replacement: paso 4, imagen 2 de 2
    • Use the flat end of a spudger to pry apart the the two pieces.
    • Lift the back panel up to separate it from the front panel.
  5. Protocol Neo-Drone AP Motor Replacement: paso 5, imagen 1 de 1
    • Pull the four motors out of the case.
    • The motors are still soldered to the motherboard.
  6. Protocol Neo-Drone AP Motor Replacement: paso 6, imagen 1 de 1
    • Here is a link to the iFixit Soldering Guide
    • Use a soldering iron to desolder the motors from the motherboard.
Conclusión
Andrew
Miembro Desde 07/05/18
291 Reputación
2 Guías creadas
Equipo
IUPUI, Team S2-G3, Harley Summer 2018 Miembro de IUPUI, Team S2-G3, Harley Summer 2018
IUPUI-HARLEY-SU18S2G3
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 402
