Saltar al contenido principal
Protocol Kaptur GPS Virtual Reality Lens Replacement
Qué necesitas
  1. Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: paso 1, imagen 1 de 3 Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: paso 1, imagen 2 de 3 Protocol Kaptur GPS Virtual Reality Lens Replacement, Virtual Reality Lens: paso 1, imagen 3 de 3
    • Remove the phone slide from the virtual reality lens.
    • Take the outside cover off using a plastic opening tool.
  2. Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 2, imagen 1 de 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 2, imagen 2 de 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 2, imagen 3 de 3
    • Remove each screw from its place.
    • Four screws will be 6mm Phillips head.
    • Twelve screws will be 7mm Phillips head.
    • Pull each bracket out so you can see the full lens case.
  3. Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 3, imagen 1 de 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 3, imagen 2 de 3 Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • You will need to remove the adjustable lens lever on top of the virtual reality lens.
    • Using a tweezers, you will need to separate the tooth gears and remove them so the lens can fall freely out.
    • Pull the lens case out from the front of the headset.
  4. Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 4, imagen 1 de 2 Protocol Kaptur GPS Virtual Reality Lens Replacement: paso 4, imagen 2 de 2
    • To get the actual lens out, you will need to push the lens from the outside in with a little force to break the lens out of it's case.
Conclusión
Austin Fedie
Miembro Desde 02/15/18
168 Reputación
1 Guía escrita
Equipo
UW Stout, Team S8-G6, Ogden Spring 2018 Miembro de UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 313
