Introducción
This guide will walk you through the 16 steps to replace the top shell of the Drone.
Qué necesitas
Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
Casi Terminas!
Conclusión
