Saltar al contenido principal
Protocol Galileo Stealth Propeller Replacement
Qué necesitas
  1. Protocol Galileo Stealth Propeller Replacement, Propeller: paso 1, imagen 1 de 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Propeller Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Propeller Replacement: paso 3, imagen 1 de 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Propeller Replacement: paso 4, imagen 1 de 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
Conclusión
Equipo
UW Stout, Team S8-G4, Ogden Spring 2018 Miembro de UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 368
