Saltar al contenido principal
Protocol Galileo Stealth Pinion Gear Replacement
Qué necesitas
  1. Protocol Galileo Stealth Pinion Gear Replacement, Propeller: paso 1, imagen 1 de 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Pinion Gear Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Pinion Gear Replacement: paso 3, imagen 1 de 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Pinion Gear Replacement: paso 4, imagen 1 de 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Pinion Gear Replacement, Housing: paso 5, imagen 1 de 2 Protocol Galileo Stealth Pinion Gear Replacement, Housing: paso 5, imagen 2 de 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Pinion Gear Replacement: paso 6, imagen 1 de 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Pinion Gear Replacement, Pinion Gear: paso 7, imagen 1 de 1
    • Lift the pinion gear off the motor shaft by lightly pulling it away from the drone.
Conclusión
Matthew Selting
Miembro Desde 02/15/18
432 Reputación
4 Guías creadas
Equipo
UW Stout, Team S8-G4, Ogden Spring 2018 Miembro de UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Miembros
6 Guías creadas
2 comentarios
where can i get pinion gears at
steve Litchfield - Contestar
where can i purchase pinion gears
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 229
