Introducción
This guide will walk you through how to replace the light emitting diodes (LED) on the drone. Minimal tooling is required, but the risk of damaging the drone is greater then many of the other guides if each step is not followed and executed with extra care.
Qué necesitas
Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
Casi Terminas!
Conclusión
