Introducción
This guide will walk you through how to safely and effectively remove the battery from your drone. This is a relatively simple process that does not require any tools or prerequisite steps. This guide is not required to charge your drone battery, but may be useful if the battery becomes defective.
  1. Locate the door to the battery compartment on the underside of the drone.
    • Locate the door to the battery compartment on the underside of the drone.
  2. Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
    • Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. First pull out the wires located to the side of the battery.
    • First pull out the wires located to the side of the battery.
    • Carefully remove the battery from the battery compartment
    • The battery can be a bit difficult to remove, but if the wires are held firmly to the battery, the battery will eventually come out by lightly pulling on the battery and wires simultaneously.
    • The small black and white wire with the white plug will not be connected to the drone, just be sure the plug does not get stuck in the battery compartment and damaged while removing the battery. This is rarely an issue.
  5. Disconnect the two ends of the wires by lightly pulling them apart.
    • Disconnect the two ends of the wires by lightly pulling them apart.
Conclusión
Equipo
UW Stout, Team S8-G4, Ogden Spring 2018 Miembro de UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 92
