Saltar al contenido principal
Protocol Galileo Pinion Gear Replacement
Qué necesitas
  1. Protocol Galileo Pinion Gear Replacement, Battery: paso 1, imagen 1 de 1
    • Find door on the underside of drone. Open the door.
  2. Protocol Galileo Pinion Gear Replacement: paso 2, imagen 1 de 2 Protocol Galileo Pinion Gear Replacement: paso 2, imagen 2 de 2
    • Carefully pull out battery, pulling out wires first.
  3. Protocol Galileo Pinion Gear Replacement: paso 3, imagen 1 de 1
    • Disconnect the connecter.
    • When reconnecting, remember to match up the black wire with the black wire and the red with red.
  4. Protocol Galileo Pinion Gear Replacement, Propeller: paso 4, imagen 1 de 2 Protocol Galileo Pinion Gear Replacement, Propeller: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Heavy-Duty Spudger
    Comprar
    • Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
  5. Protocol Galileo Pinion Gear Replacement: paso 5, imagen 1 de 1
    • Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
  6. Protocol Galileo Pinion Gear Replacement: paso 6, imagen 1 de 1
    Comprar
  7. Protocol Galileo Pinion Gear Replacement: paso 7, imagen 1 de 1
    • Pull off white spindle sleeve.
    • Take note of which side of the spindle sleeve is the top.
  8. Protocol Galileo Pinion Gear Replacement: paso 8, imagen 1 de 2 Protocol Galileo Pinion Gear Replacement: paso 8, imagen 2 de 2
    • Pull off propeller.
  9. Protocol Galileo Pinion Gear Replacement, Top Shell: paso 9, imagen 1 de 3 Protocol Galileo Pinion Gear Replacement, Top Shell: paso 9, imagen 2 de 3 Protocol Galileo Pinion Gear Replacement, Top Shell: paso 9, imagen 3 de 3
    • Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
  10. Protocol Galileo Pinion Gear Replacement: paso 10, imagen 1 de 2 Protocol Galileo Pinion Gear Replacement: paso 10, imagen 2 de 2
    • Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
  11. Protocol Galileo Pinion Gear Replacement: paso 11, imagen 1 de 3 Protocol Galileo Pinion Gear Replacement: paso 11, imagen 2 de 3 Protocol Galileo Pinion Gear Replacement: paso 11, imagen 3 de 3
    • Unplug the camera wire.
    • Press the hold release button and slide out the camera module away from the button.
  12. Protocol Galileo Pinion Gear Replacement: paso 12, imagen 1 de 2 Protocol Galileo Pinion Gear Replacement: paso 12, imagen 2 de 2
    • Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
  13. Protocol Galileo Pinion Gear Replacement: paso 13, imagen 1 de 3 Protocol Galileo Pinion Gear Replacement: paso 13, imagen 2 de 3 Protocol Galileo Pinion Gear Replacement: paso 13, imagen 3 de 3
    • Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
  14. Protocol Galileo Pinion Gear Replacement: paso 14, imagen 1 de 1
    • Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
  15. Protocol Galileo Pinion Gear Replacement: paso 15, imagen 1 de 2 Protocol Galileo Pinion Gear Replacement: paso 15, imagen 2 de 2
    • Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
  16. Protocol Galileo Pinion Gear Replacement: paso 16, imagen 1 de 3 Protocol Galileo Pinion Gear Replacement: paso 16, imagen 2 de 3 Protocol Galileo Pinion Gear Replacement: paso 16, imagen 3 de 3
    • Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
  17. Protocol Galileo Pinion Gear Replacement, Pinion Gear: paso 17, imagen 1 de 1
    • Remove the motor assembly from the bottom shell.
  18. Protocol Galileo Pinion Gear Replacement: paso 18, imagen 1 de 2 Protocol Galileo Pinion Gear Replacement: paso 18, imagen 2 de 2
    • Slide the pinion gear off of the motor assembly.
Conclusión
Thomas Ramey
Miembro Desde 02/03/17
301 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team 2-3, Rose Winter 2017 Miembro de UW Tacoma, Team 2-3, Rose Winter 2017
UWT-ROSE-W17S2G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 352
