Saltar al contenido principal
Protocol Dronium Two Rechargeable Battery Replacement
Qué necesitas
  1. Protocol Dronium Two Rechargeable Battery Replacement, Rechargeable Battery: paso 1, imagen 1 de 1
    • Turn the drone off by moving the selector switch to the left.
  2. Protocol Dronium Two Rechargeable Battery Replacement: paso 2, imagen 1 de 1
    • On the underside of the drone, gently pull the battery compartment away from the drone.
    • Press down on the camera as shown to get a better grip.
  3. Protocol Dronium Two Rechargeable Battery Replacement: paso 3, imagen 1 de 2 Protocol Dronium Two Rechargeable Battery Replacement: paso 3, imagen 2 de 2
    • If the power cable of the battery is connected to the drone, remove it by gently pulling it out.
  4. Protocol Dronium Two Rechargeable Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery from its compartment by sliding it out away from the drone.
Conclusión
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 548
