Introducción
This simple guide will help you replace your damaged rotor guards. By changing the rotor guards, it will help your drone fly properly.
Qué necesitas
Remove the 9.1mm rotor guard screw found directly under the rotor blade using a Phillips 000 screwdriver.
Casi Terminas!
Conclusión
