Saltar al contenido principal
Protocol Dronium III AP Light Bulb Replacement
Qué necesitas
  1. Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: paso 1, imagen 1 de 2 Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: paso 1, imagen 2 de 2
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
  2. Protocol Dronium III AP Light Bulb Replacement: paso 2, imagen 1 de 1
    • Remove battery pack from body of drone.
  3. Protocol Dronium III AP Light Bulb Replacement: paso 3, imagen 1 de 2 Protocol Dronium III AP Light Bulb Replacement: paso 3, imagen 2 de 2
    • Disconnect white connectors between the battery pack and drone.
  4. Protocol Dronium III AP Light Bulb Replacement, L.E.D. Bulb(s): paso 4, imagen 1 de 1
    • Remove the eight (8) 5mm Philips screws attaching the motor arms to the body using a Philips J00 screwdriver.
  5. Protocol Dronium III AP Light Bulb Replacement: paso 5, imagen 1 de 2 Protocol Dronium III AP Light Bulb Replacement: paso 5, imagen 2 de 2
    • Remove the six (6) 5mm Philips screws attaching the Body Cover to the Body of the drone using a Philips J00 screwdriver.
    • Remove the Body Cover.
  6. Protocol Dronium III AP Light Bulb Replacement: paso 6, imagen 1 de 2 Protocol Dronium III AP Light Bulb Replacement: paso 6, imagen 2 de 2
    • Remove the two (2) 5mm Philips screws attaching the Motherboard to the body of the drone using a Philips J00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
  7. Protocol Dronium III AP Light Bulb Replacement: paso 7, imagen 1 de 2 Protocol Dronium III AP Light Bulb Replacement: paso 7, imagen 2 de 2
    • This step contains a tool that can present a potential burn hazard.
    • Prepare and warm up a soldering iron.
    • Position Motherboard so that the L.E.D. bulb solder joints are accessible.
    • Use the soldering iron to melt the solder joints.
    • For more detailed instructions on how to solder, visit out How to Solder and Desolder Connections guide.
    • Remove the L.E.D. bulb from the Motherboard
Conclusión
Steven Mooers
Miembro Desde 10/18/17
401 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G1, Rose Fall 2017 Miembro de UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 236
