Saltar al contenido principal
Protocol Dronium III AP Camera Replacement
Qué necesitas
  1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: paso 1, imagen 1 de 2 Protocol Dronium III AP Camera Replacement, Drone Battery Pack: paso 1, imagen 2 de 2
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
  2. Protocol Dronium III AP Camera Replacement: paso 2, imagen 1 de 1
    • Remove battery pack from body of drone.
  3. Protocol Dronium III AP Camera Replacement: paso 3, imagen 1 de 2 Protocol Dronium III AP Camera Replacement: paso 3, imagen 2 de 2
    • Disconnect white connectors between the battery pack and drone.
  4. Protocol Dronium III AP Camera Replacement, Camera: paso 4, imagen 1 de 1
    • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
  5. Protocol Dronium III AP Camera Replacement: paso 5, imagen 1 de 2 Protocol Dronium III AP Camera Replacement: paso 5, imagen 2 de 2
    • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
    • Remove the Body Cover.
  6. Protocol Dronium III AP Camera Replacement: paso 6, imagen 1 de 2 Protocol Dronium III AP Camera Replacement: paso 6, imagen 2 de 2
    • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
  7. Protocol Dronium III AP Camera Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the tape covering the camera with the tweezers.
  8. Protocol Dronium III AP Camera Replacement: paso 8, imagen 1 de 2 Protocol Dronium III AP Camera Replacement: paso 8, imagen 2 de 2
    • Remove the plastic holding the ribbon cable connector with the tweezers.
    • Be careful with the ribbon cable, it is easy to damage.
  9. Protocol Dronium III AP Camera Replacement: paso 9, imagen 1 de 1
    • Move the ribbon cable out of the way with the Spuger.
  10. Protocol Dronium III AP Camera Replacement: paso 10, imagen 1 de 2 Protocol Dronium III AP Camera Replacement: paso 10, imagen 2 de 2
    • Remove the camera by gently prying it out of the bracket with the spudger.
Conclusión
Steven Mooers
Miembro Desde 10/18/17
401 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G1, Rose Fall 2017 Miembro de UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 305
