Saltar al contenido principal
ProntoTec Axius Screen Replacement
Qué necesitas
  1. ProntoTec Axius Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
    • Place the tablet face-up on a flat table
  2. ProntoTec Axius Screen Replacement: paso 2, imagen 1 de 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Screen Replacement: paso 3, imagen 1 de 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Screen Replacement: paso 4, imagen 1 de 1
    • Remove all of the yellow tape that is on the device with the spudger.
    • Be careful not to cut any wires that are under the tapes.
  5. ProntoTec Axius Screen Replacement: paso 5, imagen 1 de 2 ProntoTec Axius Screen Replacement: paso 5, imagen 2 de 2
    • Use the flat end of the spudger to gently pry the battery from the back of the screen.
  6. ProntoTec Axius Screen Replacement: paso 6, imagen 1 de 2 ProntoTec Axius Screen Replacement: paso 6, imagen 2 de 2
    • Use a spudger to lift all the ribbon cable clamps
    • Detach all three ribbon cables from the clamps
  7. ProntoTec Axius Screen Replacement: paso 7, imagen 1 de 3 ProntoTec Axius Screen Replacement: paso 7, imagen 2 de 3 ProntoTec Axius Screen Replacement: paso 7, imagen 3 de 3
    • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
  8. ProntoTec Axius Screen Replacement: paso 8, imagen 1 de 3 ProntoTec Axius Screen Replacement: paso 8, imagen 2 de 3 ProntoTec Axius Screen Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Heavy-Duty Spudger
    Comprar
    • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
    • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
  9. ProntoTec Axius Screen Replacement: paso 9, imagen 1 de 1
    • Remove the orange tab from the back of the screen as shown in the picture
  10. ProntoTec Axius Screen Replacement: paso 10, imagen 1 de 2 ProntoTec Axius Screen Replacement: paso 10, imagen 2 de 2
    • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
Conclusión
Antonio Irons
Miembro Desde 10/20/16
441 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-3, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 270
