Saltar al contenido principal
Promowide SP1790 Charging Port Replacement
Qué necesitas
  1. Promowide SP1790 Charging Port Replacement, Battery Wire: paso 1, imagen 1 de 1
    • Locate the six screws on the back of the speaker.
  2. Promowide SP1790 Charging Port Replacement: paso 2, imagen 1 de 1
    • Unscrew each of the six screws, then set them aside.
  3. Promowide SP1790 Charging Port Replacement: paso 3, imagen 1 de 1
    • Gently remove the back cover of the speaker.
  4. Promowide SP1790 Charging Port Replacement: paso 4, imagen 1 de 1
    • Place the speaker upside down.
    • Remove the battery cover located in the center of the speaker.
  5. Promowide SP1790 Charging Port Replacement: paso 5, imagen 1 de 1
    • Locate and remove the four screws under each of the pads near the power socket.
  6. Promowide SP1790 Charging Port Replacement: paso 6, imagen 1 de 1
    • Gently remove the bottom.
    • Do NOT pull out or damage wires.
  7. Promowide SP1790 Charging Port Replacement: paso 7, imagen 1 de 1
    • Remove the single motherboard screw.
  8. Promowide SP1790 Charging Port Replacement: paso 8, imagen 1 de 1
    • Remove both of the screws holding the power socket to the bottom chassis.
  9. Promowide SP1790 Charging Port Replacement: paso 9, imagen 1 de 1
    • Desolder and remove the old wire.
    • Insert the new wire and solder it into place.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 996
