Saltar al contenido principal
Professional Series PS77401 Lever Spring Replacement
Qué necesitas
  1. Professional Series PS77401 Lever Spring Replacement, Shell: paso 1, imagen 1 de 1
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Professional Series PS77401 Lever Spring Replacement: paso 2, imagen 1 de 2 Professional Series PS77401 Lever Spring Replacement: paso 2, imagen 2 de 2
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Professional Series PS77401 Lever Spring Replacement: paso 3, imagen 1 de 3 Professional Series PS77401 Lever Spring Replacement: paso 3, imagen 2 de 3 Professional Series PS77401 Lever Spring Replacement: paso 3, imagen 3 de 3
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Professional Series PS77401 Lever Spring Replacement: paso 4, imagen 1 de 2 Professional Series PS77401 Lever Spring Replacement: paso 4, imagen 2 de 2
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
  5. Professional Series PS77401 Lever Spring Replacement, Lever Spring: paso 5, imagen 1 de 1
    • Locate your damaged spring that holds the toaster lever in place.
    • The spring in the picture is not damaged.
  6. Professional Series PS77401 Lever Spring Replacement: paso 6, imagen 1 de 2 Professional Series PS77401 Lever Spring Replacement: paso 6, imagen 2 de 2
    • Disconnect the bottom part of the damaged spring from the lever first.
    • Then disconnect the top part of the damaged spring from the chassis.
  7. Professional Series PS77401 Lever Spring Replacement: paso 7, imagen 1 de 2 Professional Series PS77401 Lever Spring Replacement: paso 7, imagen 2 de 2
    • Attach the new spring in the same spots that the damaged spring was removed from.
    • Check to make sure that the new spring allows the lever to move down with slight resistance and that it pops back up after being released.
Conclusión
David Acosta
Miembro Desde 01/24/14
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-36, Maness Winter 2014 Miembro de Cal Poly, Team 10-36, Maness Winter 2014
CPSU-MANESS-W14S10G36
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,411
