Saltar al contenido principal
ProScan PLT7223G Speakers Replacement
Qué necesitas
  1. ProScan PLT7223G Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Speakers Replacement: paso 2, imagen 1 de 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Speakers Replacement: paso 3, imagen 1 de 1
    • Pull back the protective tape from the two wires that connect the speakers to the motherboard.
  4. ProScan PLT7223G Speakers Replacement: paso 4, imagen 1 de 1
    • Use the soldering tool to remove speaker wires from motherboard.
    • Soldering tool will get hot, handle with care.
  5. ProScan PLT7223G Speakers Replacement: paso 5, imagen 1 de 2 ProScan PLT7223G Speakers Replacement: paso 5, imagen 2 de 2
    • If needed use a plastic opening tool to remove speaker from the speaker port on the tablet.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 327
