Saltar al contenido principal
ProScan PLT7223G Motherboard Replacement
Qué necesitas
  1. ProScan PLT7223G Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
  2. ProScan PLT7223G Motherboard Replacement: paso 2, imagen 1 de 1
    • Use the blue opening tool to pry the tablet open.
  3. ProScan PLT7223G Motherboard Replacement: paso 3, imagen 1 de 2 ProScan PLT7223G Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove all yellow tape from the motherboard.
  4. ProScan PLT7223G Motherboard Replacement: paso 4, imagen 1 de 3 ProScan PLT7223G Motherboard Replacement: paso 4, imagen 2 de 3 ProScan PLT7223G Motherboard Replacement: paso 4, imagen 3 de 3
    • With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
    • Pay close attention to where each wire goes, so that you reconnect them in the correct order.
  5. ProScan PLT7223G Motherboard Replacement: paso 5, imagen 1 de 3 ProScan PLT7223G Motherboard Replacement: paso 5, imagen 2 de 3 ProScan PLT7223G Motherboard Replacement: paso 5, imagen 3 de 3
    • Lift all three ZIF connectors to disconnect the ribbon wire.
  6. ProScan PLT7223G Motherboard Replacement: paso 6, imagen 1 de 1
    • Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
  7. ProScan PLT7223G Motherboard Replacement: paso 7, imagen 1 de 1
    • Lift the motherboard off the device.
Conclusión
2 personas más completaron esta guía.
Un comentario
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
rainbowsend14 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,493
