Introducción
This is the replacement guide for the screen. If the screen is broken , use this guide to replace the screen
Qué necesitas
Make sure device is unplugged and turned off while working on the device.
Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
Remove the 3 black pieces of tape from the device.
Remove the 5 yellow pieces of tape from the device.
Use one of the plastic opening tools next to one of the black clips on the side of silver screen.
Use the second plastic opening tool to push back the black clip next to the one you have worked on. Push the second plastic opening tool under the screen.
