Saltar al contenido principal
ProScan PLT7050 Camera Replacement
Qué necesitas
  1. ProScan PLT7050 Camera Replacement, Open Device: paso 1, imagen 1 de 1
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Camera Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Camera Replacement, Camera: paso 3, imagen 1 de 1
    • Remove the black tape carefully.
  4. ProScan PLT7050 Camera Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to open the ZIF connector tab to release the camera's ribbon cable.
  5. ProScan PLT7050 Camera Replacement: paso 5, imagen 1 de 1
    • Remove the camera's ribbon cable.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 189
