Introducción
We disassemble a broken Princess toaster into its most basic elements. We try to damage the least amount of parts possible, so we for example only cut a piece when absolutely necessary.
Qué necesitas
Turn the toaster 90 degrees so that you can see the bottom.
To further dissamble the toaster you will need to twist more metal clips and break the pop nails that hold the base plate and some other parts together. We did not go further since for repair you will probably not need to disassemble the product further. Therefore this is our final exploded view of our disassembly.
Una persona más ha completado esta guía.
