Introducción
These instructions explain how to take apart the popcorn popper. This could be useful if it is not working properly or if the stirrer is jammed. The only tool needed is a #2 Phillips screwdriver. All the screws except the four large screws attaching the base to the heating plate are identical. Be careful with exposed wires and do not plug in the popper without the wires connected properly.
Qué necesitas
Detach the cover/serving bowl from the popper.
Flip the base of the popper over and remove the four 14 mm Phillips #2 screws attaching the bottom cover to the base.
