Introducción
This is a replacement guide for the Popping Chamber shaft. The shaft may need to be replaced if it has been coated with any popcorn residue that could not be cleaned out. Be sure that the PopLite is unplugged from the wall and has had time after use to cool down before working on the device.
Qué necesitas
The popping chamber shaft should be located in the popper base once the chute is removed.
Una persona más ha completado esta guía.
