Saltar al contenido principal
Prerequisite Only
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Prerequisite Only, Prerequisite Only: paso 1, imagen 1 de 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Prerequisite Only: paso 2, imagen 1 de 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Prerequisite Only: paso 3, imagen 1 de 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Prerequisite Only: paso 4, imagen 1 de 2 Prerequisite Only: paso 4, imagen 2 de 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Prerequisite Only: paso 5, imagen 1 de 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Prerequisite Only: paso 6, imagen 1 de 3 Prerequisite Only: paso 6, imagen 2 de 3 Prerequisite Only: paso 6, imagen 3 de 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
Conclusión
Joshua Meines
Miembro Desde 10/19/16
316 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-5, Baechle Fall 2016 Miembro de IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 49
