Saltar al contenido principal
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
Qué necesitas
  1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: paso 1, imagen 1 de 2 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: paso 1, imagen 2 de 2
    • Plug in the tree.
    • Use a Christmas light function tester to check the fuse on a light that is not bright.
    • The red light on the function tester will not light up if the fuse is dead.
  2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 2, imagen 1 de 1
    • Unplug the tree from the outlet.
  3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 3, imagen 1 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 3, imagen 2 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 3, imagen 3 de 3
    • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
  4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 4, imagen 1 de 1
    • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
    • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
  5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 5, imagen 1 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 5, imagen 2 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 5, imagen 3 de 3
    • Carefully insert the working fuse back into the tree plug, and put the cover on.
  6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 6, imagen 1 de 1
    • Plug the tree back into the outlet.
  7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: paso 7, imagen 1 de 1
    • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
    • The red light will appear whether the bulb itself is working or not.
Conclusión
Thank you for using this guide!
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,195
