Saltar al contenido principal
PowerLead Puto PLD003 Screen Replacement
Qué necesitas
  1. PowerLead Puto PLD003 Screen Replacement, Side Panel: paso 1, imagen 1 de 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Screen Replacement: paso 2, imagen 1 de 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Screen Replacement: paso 3, imagen 1 de 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Screen Replacement: paso 4, imagen 1 de 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Screen Replacement, Screen: paso 5, imagen 1 de 2 PowerLead Puto PLD003 Screen Replacement, Screen: paso 5, imagen 2 de 2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Screen Replacement: paso 6, imagen 1 de 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Screen Replacement: paso 7, imagen 1 de 1
    • Remove the back panel away from the camera by applying pressure to it.
  8. PowerLead Puto PLD003 Screen Replacement: paso 8, imagen 1 de 2 PowerLead Puto PLD003 Screen Replacement: paso 8, imagen 2 de 2
    • Set aside back panel for now.
    • Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
  9. PowerLead Puto PLD003 Screen Replacement: paso 9, imagen 1 de 1
    • Carefully apply pressure, away from the camera, to the screen to detach it from the body.
    • The white cord should still be connected to the body.
  10. PowerLead Puto PLD003 Screen Replacement: paso 10, imagen 1 de 2 PowerLead Puto PLD003 Screen Replacement: paso 10, imagen 2 de 2
    • Lift the black clip upward.
    • With the clip up, pull the white cord to the left. This will detach the screen from the body.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 201
