Saltar al contenido principal
PowerBook G4 Titanium Onyx Lower Case Replacement
Qué necesitas
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
  1. PowerBook G4 Titanium Onyx Lower Case Replacement: paso 2, imagen 1 de 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  2. PowerBook G4 Titanium Onyx Lower Case Replacement: paso 3, imagen 1 de 1
    • Your laptop should look approximately like this.
Conclusión
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 4,095
