Saltar al contenido principal
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement
Qué necesitas
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: paso 1, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Memory Door: paso 2, imagen 1 de 1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: paso 3, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: paso 3, imagen 2 de 2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: paso 4, imagen 1 de 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: paso 4, imagen 2 de 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: paso 4, imagen 3 de 3
    • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
    • Pull the RAM chip away from its socket and remove it from the logic board.
    • Repeat this process for the other RAM chip, if present.
Conclusión
24 personas más completaron esta guía.
Documentos Adjuntos
Un comentario
What is the maximum ram that I can bump up this system to?
Legendary Ocelot - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 8,324
