Introducción
Replace your optical drive to regain disk-reading ability.
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
Use the flat end of a spudger to separate the optical drive connector from the optical drive.
If necessary, pull the optical drive cable away from the optical drive.
4 personas más completaron esta guía.
