Saltar al contenido principal
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement
Qué necesitas
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Battery: paso 1, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Memory Door: paso 2, imagen 1 de 1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 3, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 3, imagen 2 de 2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Upper Case: paso 4, imagen 1 de 1
    • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
  5. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 5, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 5, imagen 2 de 2
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 6, imagen 1 de 1
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 7, imagen 1 de 1
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 8, imagen 1 de 1
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  9. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 9, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 9, imagen 2 de 2
    • Depress the display latch release button and open your display.
  10. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 10, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 10, imagen 2 de 2
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
  11. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Optical Drive: paso 11, imagen 1 de 1
    • Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
  12. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 12, imagen 1 de 1
    • Remove the following four screws securing the optical drive to the lower case:
    • Three 6.8 mm T8 Torx.
  13. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 13, imagen 1 de 1
    • Lift the optical drive out of the lower case, being careful not to disturb the PRAM battery & USB board ribbon cable.
  14. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Optical Drive: paso 14, imagen 1 de 1
    • Use the flat end of a spudger to separate the optical drive connector from the optical drive.
    • If necessary, pull the optical drive cable away from the optical drive.
  15. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 15, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 15, imagen 2 de 2
    • Remove the two Phillips screws holding the optical drive bracket to the side of the optical drive.
    • Pull the optical drive bracket away from the thin side of the optical drive.
  16. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 16, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: paso 16, imagen 2 de 2
    • Remove the two Phillips screws securing the flat optical drive bracket to the side of the optical drive.
    • Remove the optical drive bracket.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
Conclusión
4 personas más completaron esta guía.
Documentos Adjuntos
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 46
Todo El Tiempo: 10,005
