Saltar al contenido principal
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement
Qué necesitas
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: paso 1, imagen 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Conclusión
2 personas más completaron esta guía.
Documentos Adjuntos
Un comentario
Where can I find new condition batteries for this. I can’t seem to find any compatable ones.
Legendary Ocelot - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 3,117
