Introducción
Replace your optical drive to regain disk-reading ability.
Use your thumbs to push the two battery retaining tabs away from the battery.
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Agregar Comentario
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Agregar Comentario
  • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Agregar Comentario
  • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
Agregar Comentario
  • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
  • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
  • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
The ZIF cable locks are the little grey pieces seen on the cable-side ends of the white bar. They will slide, as per detailed picture, toward the cable.
web - Contestar
  • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
Agregar Comentario
  • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
  • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
Agregar Comentario
  • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
  • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
Agregar Comentario
  • Depress the display latch release button and open your display.
Agregar Comentario
  • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Sometimes the "tags"/"lugs" that are around the edge of the top & bottom frame, be careful not to bend them as when putting back the covers they will not merge. I used a screwdriver to poke through the hole the screw was supposed go in & push against the "inside nut" to let the tag from the top slide down between the 2 tags. The "inside nut" is like the one right next to the ribbon cable as shown in Dia.14. The screws are from Dia. 7&8.
harry allcock - Contestar
in what direction does one move the ZIF cable lock? what/where is its socket?
Ian - Contestar
When putting the machine back together (following steps in reverse), make sure the trackpad ribbon cable comes through the underside of the computer — there is an opening that the cable needs to go through and you will want to “thread the needle” with the cable before securing the upper case again.
Tim - Contestar
  • Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
Agregar Comentario
  • Remove the following four screws securing the optical drive to the lower case:
    • Three 6.8 mm T8 Torx.
Agregar Comentario
  • Lift the optical drive out of the lower case, being careful not to disturb the PRAM battery & USB board ribbon cable.
Agregar Comentario
  • Use the flat end of a spudger to separate the optical drive connector from the optical drive.
  • If necessary, pull the optical drive cable away from the optical drive.
Agregar Comentario
  • Remove the two Phillips screws holding the optical drive bracket to the side of the optical drive.
  • Pull the optical drive bracket away from the thin side of the optical drive.
Agregar Comentario
  • Remove the two Phillips screws securing the flat optical drive bracket to the side of the optical drive.
  • Remove the optical drive bracket.
  • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Documentos Adjuntos
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 9,523
