Introducción
This guide will show you how to remove the left fan from your PowerBook.
Herramientas
Partes
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the following 10 screws:
Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
Four 3 mm Phillips around the memory compartment.
Four 16 mm Phillips along the hinge.
Rotate the computer 90 degrees clockwise so the ports face you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Disconnect the four cables resting on the fan (shown in yellow boxes).
Remove the Phillips screws from each corner of the fan (four total).
Lift the fan out of its housing, peeling off tape as necessary.
3 personas más completaron esta guía.
