Saltar al contenido principal
Introducción
It's easy to change or upgrade the optical drive mechanism to a combo or SuperDrive.
  1. PowerBook G3 Pismo Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Use the lever at the front of your laptop to remove the optical drive bay from the computer.
    • Remove the 2 Phillips #00 screws from the left side of the optical drive housing.
    • These screws are longer than those on the other side.
  2. PowerBook G3 Pismo Optical Drive Replacement: paso 2, imagen 1 de 1
    • Remove the 2 Phillips #00 screws from the other side.
  3. PowerBook G3 Pismo Optical Drive Replacement: paso 3, imagen 1 de 1
    • Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Conclusión
6 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
646 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 28
Todo El Tiempo: 8,353
