Saltar al contenido principal
PowerBook G3 Lombard PRAM Battery Replacement
Qué necesitas
  1. PowerBook G3 Lombard PRAM Battery Replacement, Keyboard: paso 1, imagen 1 de 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard PRAM Battery Replacement: paso 2, imagen 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard PRAM Battery Replacement: paso 3, imagen 1 de 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard PRAM Battery Replacement, PRAM Battery: paso 4, imagen 1 de 1
    • Pull the battery cable directly up from the logic board.
  5. PowerBook G3 Lombard PRAM Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery from its holder by pulling up and to the left.
Conclusión
5 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
2 comentarios
Step 4, 5 and 6 are useless for changing the PRAM battery..
Godzil - Contestar
Seems the step I was referring to are no longer there!
Godzil -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 10,919
