Saltar al contenido principal
PowerBook 180 Ram Replacement
Qué necesitas
  1. PowerBook 180 Ram Replacement, Ram: paso 1, imagen 1 de 2 PowerBook 180 Ram Replacement, Ram: paso 1, imagen 2 de 2
    • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
    • Slide the battery door to the front of the computer, as directed by the arrows.
    • Pull out the battery.
  2. PowerBook 180 Ram Replacement: paso 2, imagen 1 de 2 PowerBook 180 Ram Replacement: paso 2, imagen 2 de 2
    • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
    • 4 are on the side, and one is above the modem port at the back of the computer.
    • Remove these screws.
  3. PowerBook 180 Ram Replacement: paso 3, imagen 1 de 2 PowerBook 180 Ram Replacement: paso 3, imagen 2 de 2
    • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
    • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
  4. PowerBook 180 Ram Replacement: paso 4, imagen 1 de 1
    • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
    • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
  5. PowerBook 180 Ram Replacement: paso 5, imagen 1 de 2 PowerBook 180 Ram Replacement: paso 5, imagen 2 de 2
    • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
    • Now place the new RAM into the empty socket.
    • Follow these instructions in reverse order to reassemble the PowerBook 180.
Conclusión
3 personas más completaron esta guía.
Jack Byrnes
Miembro Desde 10/17/10
1,244 Reputación
2 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,526 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 25
Todo El Tiempo: 3,174
