Introducción
The PowerBook 180 was one of Apple's top of the line notebook computers at around 1993. It was in high demand through all of its life, and had a selling price of about $3900 base model. This computer can run System 7 - 8.1 (through Born Again) and has a 68030 processor running at 33mhz.
  1. The PowerBook 180 has a removable Ni-Cad battery on the side.  Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die. Slide the battery door to the front of the computer, as directed by the arrows.
    • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
    • Slide the battery door to the front of the computer, as directed by the arrows.
    • Pull out the battery.
  2. There are 5 Torx T8 screws that hold the bottom of the PowerBook 180. 4 are on the side, and one is above the modem port at the back of the computer.
    • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
    • 4 are on the side, and one is above the modem port at the back of the computer.
    • Remove these screws.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card. Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
    • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
  5. Identify the RAM in the PowerBook 180.  It is marked in red in the picture.
    • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
    • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
  6. Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture.  The RAM is very flexible, so be very careful. Now place the new RAM into the empty socket.
    • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
    • Now place the new RAM into the empty socket.
    • Follow these instructions in reverse order to reassemble the PowerBook 180.
Conclusión
Una persona más ha completado esta guía.
Jack Byrnes
Miembro Desde 17/10/10
1,172 Reputación
2 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
286 Miembros
801 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 16
Todo El Tiempo: 1,881
