Saltar al contenido principal
PowerBook 180 Modem Replacement
Qué necesitas
  1. PowerBook 180 Modem Replacement, Modem: paso 1, imagen 1 de 2 PowerBook 180 Modem Replacement, Modem: paso 1, imagen 2 de 2
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. PowerBook 180 Modem Replacement: paso 2, imagen 1 de 2 PowerBook 180 Modem Replacement: paso 2, imagen 2 de 2
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. PowerBook 180 Modem Replacement: paso 3, imagen 1 de 2 PowerBook 180 Modem Replacement: paso 3, imagen 2 de 2
    • Your computer should look like the two pictures after the bottom plate is removed.
  4. PowerBook 180 Modem Replacement: paso 4, imagen 1 de 2 PowerBook 180 Modem Replacement: paso 4, imagen 2 de 2
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
Conclusión
3 personas más completaron esta guía.
Jack Byrnes
Miembro Desde 10/17/10
1,244 Reputación
2 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,535 Guías creadas
Un comentario
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,612
