Saltar al contenido principal
PowerA Fusion Controller For Xbox One Vibration Motors Replacement
Qué necesitas
  1. PowerA Fusion Controller For Xbox One Vibration Motors Replacement, Vibration Motors: paso 1, imagen 1 de 3 PowerA Fusion Controller For Xbox One Vibration Motors Replacement, Vibration Motors: paso 1, imagen 2 de 3 PowerA Fusion Controller For Xbox One Vibration Motors Replacement, Vibration Motors: paso 1, imagen 3 de 3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Vibration Motors Replacement: paso 2, imagen 1 de 2 PowerA Fusion Controller For Xbox One Vibration Motors Replacement: paso 2, imagen 2 de 2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Vibration Motors Replacement: paso 3, imagen 1 de 2 PowerA Fusion Controller For Xbox One Vibration Motors Replacement: paso 3, imagen 2 de 2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
Conclusión
Andrea
Miembro Desde 09/26/17
623 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S14-G4, Boczar Fall 2017 Miembro de USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 710
