Saltar al contenido principal
PowerA Enhanced1516953-01 Vibration Motors Replacement
Qué necesitas
  1. PowerA Enhanced1516953-01 Vibration Motors Replacement, Rear Case: paso 1, imagen 1 de 3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Rear Case: paso 1, imagen 2 de 3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Rear Case: paso 1, imagen 3 de 3
    • Lay the controller face down.
    • Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
    • Lift the rear case up and off of the chassis.
  2. PowerA Enhanced1516953-01 Vibration Motors Replacement, Motherboard: paso 2, imagen 1 de 3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Motherboard: paso 2, imagen 2 de 3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Motherboard: paso 2, imagen 3 de 3
    • Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
    • Lift the motherboard up and out of the chassis.
  3. PowerA Enhanced1516953-01 Vibration Motors Replacement, Vibration Motors: paso 3, imagen 1 de 3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Vibration Motors: paso 3, imagen 2 de 3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Vibration Motors: paso 3, imagen 3 de 3
    • Grip the white vibration motor connectors and pull them straight up and out of their sockets.
    • Do not pull on the wires.
    • Gently pull the connector from the pins
  4. PowerA Enhanced1516953-01 Vibration Motors Replacement: paso 4, imagen 1 de 2 PowerA Enhanced1516953-01 Vibration Motors Replacement: paso 4, imagen 2 de 2
    • Remove the four 3.3 mm Phillips screws that secure the motors.
    • Two screws secure each motor.
    • Once the second screw is removed on each motor, the vibration motor will immediately release itself. Support the motor while you remove the second screw.
Conclusión
Austin Fox
Miembro Desde 01/30/24
566 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 33
