Saltar al contenido principal
PowerA Enhanced Wireless Controller L and R buttons Replacement
Qué necesitas
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: paso 1, imagen 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: paso 1, imagen 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 2, imagen 1 de 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 3, imagen 1 de 2 PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 4, imagen 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 4, imagen 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 4, imagen 3 de 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: paso 5, imagen 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: paso 5, imagen 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: paso 5, imagen 3 de 3
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 6, imagen 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 6, imagen 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G5, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Miembros
10 Guías creadas
2 comentarios
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - Contestar
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 38
Todo El Tiempo: 3,242
