Saltar al contenido principal
PowerA Enhanced Wireless Controller L and R Thumbstick Replacement
Qué necesitas
  1. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: paso 1, imagen 1 de 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: paso 1, imagen 2 de 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: paso 2, imagen 1 de 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: paso 3, imagen 1 de 2 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: paso 4, imagen 1 de 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: paso 4, imagen 2 de 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: paso 4, imagen 3 de 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: paso 5, imagen 1 de 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: paso 5, imagen 2 de 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: paso 5, imagen 3 de 3
    • Pull the L and R sticks out of the socket.
Conclusión
11 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G5, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Miembros
10 Guías creadas
19 comentarios
My controllers are drifting, What can i do after getting the joystick of to fix that.
MilesGDC - Contestar
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
engelgott0972 - Contestar
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
Brandon Kohl -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 30
Ultimos 30 días: 190
Todo El Tiempo: 13,297
