Saltar al contenido principal
PowerA Enhanced Wireless Controller Directional Pad Replacement
Qué necesitas
  1. PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: paso 1, imagen 1 de 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: paso 1, imagen 2 de 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Directional Pad Replacement: paso 2, imagen 1 de 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Directional Pad Replacement: paso 3, imagen 1 de 2 PowerA Enhanced Wireless Controller Directional Pad Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Directional Pad Replacement: paso 4, imagen 1 de 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: paso 4, imagen 2 de 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: paso 4, imagen 3 de 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: paso 5, imagen 1 de 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: paso 5, imagen 2 de 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the rubber tweezers to grab the center of the directional pad and pull it out by pinching its center.
Conclusión
Equipo
USF Tampa, Team S1-G5, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,001
