Introducción
If your PowerA Enhanced wired Controller (Xbox) Joystick is not functioning properly, it might need to be thoroughly cleaned or replaced. In this Guide, you will find step-by-step instructions on how to not only take out your motherboard but also a guide to take off the actual joystick covers themselves. To get to the joystick, consider going through our motherboard guide.
Qué necesitas
Lay the controller face down.
Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
Lift the rear case up and off of the chassis.
Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
Lift the motherboard up and out of the chassis.
Firmly pinch the left joystick cover and lift it straight up and off.
Firmly pinch the right joystick cover and lift it straight up and off.
