Saltar al contenido principal
PowerA Enhanced 1516953-01 Front Case Replacement
Qué necesitas
  1. PowerA Enhanced 1516953-01 Front Case Replacement, Rear Case: paso 1, imagen 1 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, Rear Case: paso 1, imagen 2 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, Rear Case: paso 1, imagen 3 de 3
    • Lay the controller face down.
    • Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
    • Lift the rear case up and off of the chassis.
  2. PowerA Enhanced 1516953-01 Front Case Replacement, Motherboard: paso 2, imagen 1 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, Motherboard: paso 2, imagen 2 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, Motherboard: paso 2, imagen 3 de 3
    • Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
    • Lift the motherboard up and out of the chassis.
  3. PowerA Enhanced 1516953-01 Front Case Replacement, ABXY Buttons: paso 3, imagen 1 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, ABXY Buttons: paso 3, imagen 2 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, ABXY Buttons: paso 3, imagen 3 de 3
    • Grip and remove each button.
  4. PowerA Enhanced 1516953-01 Front Case Replacement, Front Case: paso 4, imagen 1 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, Front Case: paso 4, imagen 2 de 3 PowerA Enhanced 1516953-01 Front Case Replacement, Front Case: paso 4, imagen 3 de 3
    • Lift the bumper assembly up and out of its housing.
    • Lift the D-pad up and out of its housing.
    • Remove the ABXY buttons.
  5. PowerA Enhanced 1516953-01 Front Case Replacement: paso 5, imagen 1 de 2 PowerA Enhanced 1516953-01 Front Case Replacement: paso 5, imagen 2 de 2
    • The additional advanced buttons can be poured out from the faceplate.
Conclusión
Austin Fox
Miembro Desde 01/30/24
566 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 36
