Introducción
Are your PowerA Enhanced wired Controller (Xbox) ABXY Buttons not properly functioning? This guide will show you step by step how to take out each of the buttons to replace and or clean them.
Qué necesitas
Lay the controller face down.
Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
Lift the rear case up and off of the chassis.
Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
Lift the motherboard up and out of the chassis.
