Saltar al contenido principal
Power Macintosh G3 Blue and White Graphics Card Replacement
Qué necesitas
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: paso 1, imagen 1 de 1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: paso 2, imagen 1 de 2 Power Macintosh G3 Blue and White Graphics Card Replacement: paso 2, imagen 2 de 2
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: paso 3, imagen 1 de 1
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
Conclusión
2 personas más completaron esta guía.
[deleted]
Miembro Desde 08/28/18
26,583 Reputación
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 29
Todo El Tiempo: 1,620
