Saltar al contenido principal
Power Mac G5 Hard Drive Replacement
  1. Power Mac G5 Hard Drive Replacement, Side Panel: paso 1, imagen 1 de 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Hard Drive Replacement: paso 3, imagen 1 de 2 Power Mac G5 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Hard Drive Replacement: paso 4, imagen 1 de 3 Power Mac G5 Hard Drive Replacement: paso 4, imagen 2 de 3 Power Mac G5 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Locate hard drive on the top right-hand corner of the desktop.
  6. Power Mac G5 Hard Drive Replacement: paso 6, imagen 1 de 2 Power Mac G5 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Rotate up plastic tab labeled "B" on the right hand side of hard drive.
  7. Power Mac G5 Hard Drive Replacement: paso 7, imagen 1 de 2 Power Mac G5 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Detach both cables from the hard drive.
  8. Power Mac G5 Hard Drive Replacement: paso 8, imagen 1 de 2 Power Mac G5 Hard Drive Replacement: paso 8, imagen 2 de 2
    • Pull out the hard drive out.
  9. Power Mac G5 Hard Drive Replacement: paso 9, imagen 1 de 1
    • After hard drive is out, the space should look like this.
Conclusión
101 personas más completaron esta guía.
Jessica Chaidez
Miembro Desde 01/13/10
7,865 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Forte Winter 2010 Miembro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Miembros
18 Guías creadas
8 comentarios
I don't see why you'd need to remove the plastic cover
Petteri - Contestar
I've tried many times to remove this and my other misplaced comment duplicate, but here they'll stay apparently... you're free to delete them if you can.
Petteri -
REMOVE the plastic cover to avoid knocking it off in the process of working on the drive bays. (Just a precaution - kind of like not setting a glass of red wine on an elegant white table cloth.)
EyeSpye -
The Comments appended to these instructions are VERY helpful. If you read them you will save time, and avoid some of the mistakes I made - particularly with respect to the Drive mounting screws located to the left side of the drive installation bays, and the need to remove the bottom drive FIRST if you wish to access the top drive. THANKS for a great set of instructions.
EyeSpye - Contestar
This was helpful! Excellent photographs and clear, simple instructions. Thanks, Jessica and iFixit!
I used these instructions to remove an additional hard drive while leaving the original hard drive in place. I did not know which one to remove, as the hard drives do not have side labels, so I guessed: the original drive was on top, the additional drive on the bottom. It might be helpful for other viewers to know what to do in a similar situation.
Cheers.
Sharine Borslien - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 38
Ultimos 30 días: 150
Todo El Tiempo: 82,026
